* * would bad motor mounts cause any damage to...
infamousmarcus
118
May 18, 2004
Juneau, Alaska
i got bad motor mount inserts/bushings, so i bought new prothane ones. anyway im sure for those who know, if its bad enough you get the noise from the engines play, due to the bad mounts, well i got other noise...sounds like something from the axle or so, something rotating to be more general. I'm curious to whether anyone has any tips or any experience on something like this, because prior to takin it to a lift and lifting it up and seeing for myself, jus wanted to see if i can get a head start to what to look for other than the axle and what not.
if sounds like a ticking-poping noise and you can feel it abit while your
turning its more then likely your axle thats cooked???
i have poly mounts never had a problem with noise or anything, the axles sound like a good place to start, have there been any other ad ons to the car recently, how old are the axles?
What does the noise sound like? clicking, popping, grinding, howling? When does it make it? Is is speed dependent(more with speed) or RPM dependent(goes up with rpm, changes when you change gear)? Acceleration, deceleration?
If its rotational and sounds like its from the axle there are a few things it could be, even bearings. A little more info would help a lot.
Bad motor mounts can cause damage to the cv axles. Remeber the motor is moving back and forth freely so obviously if you hit it hard you will be applying lots of load to the axle, big no no.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
