Would a fualty MPD Sensor cause my car to run like shit?
l3igl3ang
539
Aug 10, 2005
ft smith, Arkansas
I was driven around and all sudden my CEL came on and car start bogging down and missing like crazy so i hook my dsmlink up and got the codes its saying
0300 Random missfire
1400 Manifold Differential Pressure MDP sensor malfunction
So dose that mean i have a bad MDP? and i got a 6bolt and that sensor is just hanging and not hooked up so would that cause a problem such as loseing alot of power and boggin down?
Also could i trun this off with dsmlink i read about people doing it but dont know how they did it. I dont see a opition to do so in dsmlink
The MDP sensor is just there so the ecu can see if the EGR is working correctly it dose not effect how your car runs . You should set dsmlink to ignore the MDP if you don't even have it installed. The bogging is probably from whatever is causing the misfire, the MDP code may have been a stored code (probably because the mdp is just hanging ) that did not turn the CEL light on. Clear them and set the Dsmlink to ignore the MDP and see if the your still getting the misfire CEL.
  • Wanted ISO Leveling valve assembly, Mitsu part MR135668
    Just bought a 98 Eclipse, while removing the fuel tank I accendently broke the Leveling valve...
    • briang26
  • Wanted 2g Trunk/fuel door release lever
    Looking for a 2g black fuel door/trunk release lever in good shape
    • jesse12345
  • For sale 2g parts
    Evo 3 Big 16g, xs power t4 manifold, various other parts
    • heresjimmy42
  • For sale 1G ETS street core
    1G ETS street core- USED
    • ist dwa
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
