Would a 95 automatic GSX transmission work in a 97 automatic transmission?
Boston
105
3
Mar 18, 2010
Boston, Massachusetts
Like the title states (and I couldn't find the answer by searching) would it fit? I need to know as I might move on some parts. Is it the same transmission part number or different, and any other pieces I would need? Thanks guys!:rocks:
If your switching the complete transmission you also need the transfer case. Ratios are different from 95 to 97. Went through this when I put a 95 trans/transfer case in my 97. Otherwise its a bolt in.
So I will need the transfer case. Will the Transmission shift well, or will it be off?
Did you have a thread for this? I am thinking of getting the transmission, but need to make sure
A) IT would bolt up and work
B) If it would work, what I would need.
All input appreciated; thanks!:rocks:
The individual gear ratios are the same, it's just the transfer ratio to the rear that is different.
What do you mean by the transfer ratio being different? Would getting the 95's transfer case solve this? :hmm:
So if I get the full transmission, torque converter, and transfer case, would I be set? :thumb:
look at it this way, a 95 is 2+2=4 a 97 is 3+1=4 so no matter which component you switch they will not equal to 4 unless they are of the same years(95-95, 97-99).
Rear diff ratio stays the same.
I have never heard of them changing the ratios on the automatics, only the manuals :ohdamn:
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
