WOT pull log. knocking like a champ.
I think you're seeing 96+ IDC but your AFRs look alright. May be time to pull timing and certainly time to upgrade injectors. What fuel?
Timing or boost, take your pick. You could try cleaning out your intercooler/pipes, it may lower your charge temps enough to take care of it. I don't see any boost control in your profile so I'm assuming you're on a stock turbo running something like 10 PSI on factory maps? You shouldn't really be knocking in that case.
