wont start?
illwill
66
Dec 16, 2002
Ok so im buyin a 91 tsi talon 5sp turbo from a guy for $500 "entire car " the thing is it wont start.. i havent drove it or anything but he was saything something about either fuel pump and/or ecu etc... i was curious to price on both and if this was still a good deal.. im wanting to do an engine swap with this car to my 1.8..
also .. just to make sure.. will a 91 awd talon engine bolt into a 94 talon.. 1.8.. i know one of the motor mounts wont bolt right up .. but other then that.. would i be good?
I have done the swap and eveything bolted right in for me...it was pretty straight foward im assuming you have a fwd tranny or something, any questions let me know, i think it's a good deal, check the ecu and see if its caps are leaking, thats an easy fix, the fuel pump it no biggie either as im sure you could just upgrade to a 190 or find a stock turbo one no problem.
A Bad CAS will make both the car not start and fuel pump not turn on.
as will a blow ECU fuse, Eff'd ECU , leaky caps
ingition tranistor, coil pack wont let it start either but i think the pump will kick on.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
