wiring coil pack effects starting
bls1970
Jun 1, 2010
middlebury, Indiana
i recently bought a '95 eclipse 2.0 n/t , the plug on the coil pack had been replaced but was installed poorly. The wires were spliced together and one did not have a good connection. I reconnected the wires with butt connectors and after doing so the car starts like it is out of time and is very hard to get started, but when it does finally start it runs perfect. Before i did this it started just fine with no problems.:hmm: The plug is off a different model and the colors on the three wires are different than the car.......what did i do wrong?
the ecu might be having a hard time reading it. try having a diagnostic ran on it. its free at any autoparts store. just ask them and they will test it out for you and print off the codes as well.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
