wiper fuse blows up
streetstyleauto
Feb 22, 2009
Fords, New Jersey
ok so ive replaced this fuse at least 10 times already
when i replace the fuse both wipers (front and rear) work properly
but when i press the stick for the water to come out thats when the fuse pops
please help me guys
Your washer fluid pump motor is most likely toast and that is what is causing your fuse to blow. Try unplugging the pump motor and check for voltage at the connector when operating the switch. Of course you will have to replace the fuse before testing though. If you get good voltage at the connector and your fuse doesn't blow without the pump plugged in it's your pump motor. If you still get the fuse to blow when the pump motor is unplugged you have a problem somewhere else in the wiring. Good luck:thumb:
