wiper fuse keeps blowing up
streetstyleauto
Feb 22, 2009
Fords, New Jersey
my wipers fuse keeps blowing up after i replace them
3 times already
relay is good
when i replace the fuse and turn the wiper switch i hear the fuse pop
i dont know what it could be
what should i check for
both front and rear wipers dont work
Check for a short to ground in the power wire to your wiper motorcurcuit.
Does the fuse blow with the wiper motors disconnected? If it does start looking for a short to ground in the wiring up to them (including the combonation switch). If it doesn't blow then connect each motor one at a time and see which one blows the fuse. The one that does should be inspected for high resistance/ excessive current draw. If this doesn't work let us know!
* 2 min. too late!
