Will These Rims Fit??
Rabbi
174
Mar 15, 2004
Muskegon, Michigan
Will these fit my 95 tsi fwd?
Quantity: Limited
Size/Style: 17X7 Enkei RS6 wheels
Bolt Pattern:
4-100/4-114.3/5-100/5-114.3
Offset: 38mm
Finish: SILVER
Condition: NEW
im buying new tires obviously but will these rims fit without problems?
Yes, they will fit fine. The correct bolt pattern is 5x114.3 . Have you already bought the wheels? I'd suggest going wider, at least a 17x7.5, but I strongly recommend a 17x8 if those sizes are available. Seems kind of a waste to buy new wheels but not go much wider than you had before. On a 17x7, I wouldn't go wider than a 225/45 tire.
I believe 245 is the widest tire you can run without having to roll the quarters. It may be 235, I know there is a thread with that info in it...
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
