will these 18"rims fit
SeventhEclipse
Apr 28, 2009
Rutledge, Tennessee
Im thinking about getting some 18" rims for my 96 eclipse does anyone know if these will fit
diameter - 18
Width - 8
Offset - 42
And if they won't will these
diameter - 18
Width - 8
Offset -37
Im not sure about the first choice but the second with the offset with 37 will fit.
I'd agree with this and guess that the +42 set would either just barely fit or wouldn't fit at all.
I'm running an 8" wide wheel with a +38 offset and a 245/40 tire. I've got 4mm clearance between the tire and knuckle. Using the wheel offset calculator and comparing my wheels to yours, the +42 set will be 4mm closer to the knuckle than mine are, which would put them insanely close or touching. The +37 set will fit much easier.
