Will these rims fit a stock 2G?
billhofman
Feb 28, 2008
Highland, Illinois
I have found a set of rims that have the same bolt pattern as the Eclipse's, but the offset is a little greater. The rims came off of a Mazda 6. They are a 19" rim, with a 60 mm offset, and the tire size is 245 40 R19. My question is will they fit without an adapter? I did some research and another member tried to put a set of stock Mazda 6 rims on his 2G but had to buy an adapter. On the other hand another member put on a set of Mazda 17" rims off a protige with a similar offset (55mm) without any issues. Any help would be appreciated.
