1G Will these Piston Rings work?
goalie6263
78
Sep 2, 2010
Milwaukee, Wisconsin
I'm having a bit of a dilemma. I have my 6 bolt motor that I am rebuilding 020 over with stock oversized pistons. One of the #2 piston rings broke so I wen't searching for a set. I ended up finding a Beck/Arnley set with part number 013-394820. The thing is, they don't have the same cut-away edge as the rings that I have. In the manual, this is the diagram.
The #2 ring I have has the groove directly diagonal from where it is in the picture. The number one rings don't even have a groove..Every time I search this part number, it says these rings are correct for turbo and non turbo models..
So can I use them?! If so, should I use all of these ones instead of the new ones I have? could I just use this single #2 ring and leave everything else how it is with the normal new rings?
Just get a set of the NPR rings for your application.
All the stock rod builds I have done, and the outer grooved #2 ring.
You should have a Moly top (silver face) and a napier 2nd ring.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
