Will I hurt the master cylinder if I adjust the rod out too much
Aaron91RS
148
Nov 10, 2003
St. Louis, Missouri
I had to adjust the clutch master cylinder rod out so it was just threaded flush under the dash.
After my POS ACT came apart in to 8 pieces I put in a new one.
Again it engages JUST off the floor and really unless I stomp it hard its not safe to drive.
The pedal assembly has already been taken out and welded BTW to get rid of the wallowing problem.
Anyway I want to weld or sleave an extension so I can unscrew the master clutch rod a bit father. I'm worried at some point though when I push it in it will just hit the far side of the master cylinder housing and ???
Is it just going to stop the clutch pedal. Will it break the plunger and blow out the master cylinder?
No sir you woll not. You are more likely to hurt the slave, slave rod, clutch assembly and clutch linkage. The rod is there for you to adjust. It ends up where it ends up.
Steven
I would seriously look into the things i stated above first.If one of thos is your problem it will have to be corrected sooner than later.
But if you insist on welding an extension i would do it on the slave, easier to get to,easier to replace and cost less to replace.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
