?s About Welding Clutch Master Cylinder Rod!
turbotsi92
342
Sep 15, 2004
Morgantown, West Virginia
I have been having problems with my ACT 2600 and streetlite flywheel since I put them it. I have tried a longer slave cylinder extension rod, I adjusted as much as possible under the dash, and I have been reading about welding the clutch master cylinder rod. Is that the rod I adjusted under the dash, and if so do I have to weld a piece on the end to make it longer or what? Also how long does the piece need to be if I have to weld one on the end? Thanks
you probably have a worn clutch pedal assembly. from what i hear this is a bi*** to install, but you can buy one from www.diamondstarmotorsport.com
as far as welding it is concerned i hear its a bi*** to do that too But you weld a nut on the end of the nut that the master cylinder screws into. so you will have 2 nuts welded together.
hope that helps
