Will Evo 8 or 9 gauges work in a 2g?
96DSM_Steve
262
5
Aug 19, 2010
Bakersfield, California
I have a question on if the Evo three pod Temp, Volt, and Boost gauges work in a 2g?
Sent from my iPhone using Tapatalk
Assuming you can get the sensors for them. Gauges are pretty much universal which require at the least, a signal source. The signal could simply be a mechanical line i.e. boost gauge vacuum tube to operate the needle. Mechanical gauges only need power and ground for illumination.
Digital gauges will require a signal from a sensor whether it's a pressure sensor or temp sensor. They also need the power and ground to work aside from illumination. Not all sensors will work with other gauges. The OEM oil pressure sensor doesn't exactly work for an aftermarket oil pressure gauge.
So be sure to acquire the sensors assuming the gauges are digital so you can have proper function.
