Clutch450
- 252
- 1
- Jan 15, 2009
Lancaster,
Pennsylvania
I've been searching the forums for a while now trying to get a good answer for this.
I recently picked up an Evo 8 steering wheel and have followed the DIY. Welding it to a 1g hub so it will bolt right up to my 2g column.
I also was able to get the air bag connector from the car side of the Evo harness.
My question is: Is it a possibility to cut and solder/splice this connector into my current 2g harness? So that I will have a working airbag once the Evo wheel is hooked up.
My main concern is setting the airbag off for some reason because the connector doesn't "comply" with the harness.
Any advice would be appreciated!
Edit** I apologize for taking up the space.
I went back and reread the original DIY and there is a picture right there!
