Will a stock NA Intake Manifold hold up to a turbo?
NiKKUH_BOViCE
162
Sep 20, 2009
Brunswick, New Jersey
I was wondering if a stock intake manifold hold up to a bolt on turbo? Also I heard that the fuel rail is the same on all 2.0 engines, if so i guess I wont need to get a new one?
What do you mean hold up? It's not going to blow apart if that is what you mean. It is made just like the turbo one. The same process that is.
yeah thats what I meant i wanted to know if i will need a manifold off a turbo car or i could use my existing one with a turbo.
The manifold will be fine, just have to find a nice spot and drill and tap a nipple for the BOV line. However the Fuel rail is in fact different. I think the Turbo one is Longer... I know for a fact I tried a N/A one and it wouldnt work.
CAPS/ASA lists exactly 2 fuel rails for the 1G 4G63. One for the 90 cars and one for the 91-94 cars. No difference between N/T and turbo.
Based on the reports I've read, the 90 fuel rail is longer than the 91+ rail because the 90 one would hit the TPS on the later cars or if you swap a 91+ TB onto a 90 car..
Yep ive disasembed my car every year this year is no execption, pulling it this spring for major clean up, i would like some new injectors but well see.
