4Motion4g63
- 257
- 1
- Feb 27, 2005
Lawton,
Oklahoma
It is possible to have a good tune and no knock sensor, but only marginally on a stock or modified stock ECU..but
Very possible on a stand alone where there's no uncontrolable variable tables. I have ran for 9 years with no knock sensor, tuning way more aggresively than the stock 1g ECU even and on plain pump gas (keeping boost at 20 and under normally) i have only blown one motor i those 9 years. I now have a knock system that's far superior than a stock one so I am only know starting to even care what a knock snesor has to say in any situation other than on the dyno for the first time in 10 years. At least this units not a hypocondriac like the mitsu one though.
but with a carefull ear eye and mind you can achieve a good tune without a knocki sensor and a hard running tune at that. But honestly if you're not considering yourself an "advanced tuner" minimum, don't even try it.
I ran Without a Knock sensor for at least 4 years, OVERBOOSTED my 14b to 20+lbs or better my gauge goes to 20lbs, Stock Fuel system Stock everything except a exaust and a hks intake and greddy bov, Just didnt realize it was Overboosting due to a failed MBC till I put the gauge on it. Still Pulled better when it had NO Knock sensor..I even Unplug it when the going gets tough and need to wax a Stang after it outran me due to pulled timing....
Still the motor was fine and still fine drives daily and USE to be faster without stupid knock sensor, I have a few rattles thu my drivetrain and my valvetrain, causing phantom knock..
