m_0ney_pit
- 819
- 87
- Jan 12, 2007
Easton,
Pennsylvania
My question is will a leaking wastegate flapper effect timing on the ecu?
I ask because every once and a while I can hear an awkward noise come from my dump tube when I'm coming out of vacuum and on my logger timing gets pulled waaaay back to 0-4 degrees and the fuel trims go nuts and way rich. And let me just say, its NOT a vacuum/boost leak.
I'm thinking I ported out the housing a little to much on the one side when I did my 34mm flapper.
Does a leaking flapper cause a rich condition?
