Will a Evo 3 ecu work on a 1G?
If you got it together with harness, it would. The socket is different than a 1G so an adapter harness would be required otherwise. Might as well jump straight to the Evo 8 ecu if you consider making an adapter harness.
Here's a couple link to the pinout of the Evo I-III Ecu harness Pin out PDF and the Pin out to the later Evo-IV-VIII Here
Also there are differences between the USDM evo 8 and the EDM 8(260)
Here is the USDM Evo VIII pin out
If this is something you plan on doing...
