will a AWD clutch work in a FWD tranny?
l3igl3ang
539
Aug 10, 2005
ft smith, Arkansas
Yeah i got a m8 who is selling his preformence clutch from his awd in a part out of his car and i was wondering if it would work in my FWD gst?
its a 1g awd tranny and mine is a 2g fwd
Go to autozone.com or advanceautoparts.com and see if the clutch part numbers are the same for a 1g awd and a 2g fwd. That's how i check for part interchangeability.
All 4g63 clutches are interchangeable. 1g or 2g, AWD or FWD, turbo or NT. As long as its a 4g63 the clutch will swap.
The flywheels, however, are not interchangeable. You must have the correct flywheel for the application.
yeah im going to buy his 6bolt motor from him it was rebuilt only like 3 months ago and has very little miles on it and it is from a GSX so will i need to take my flywheel off my 7bolt GST and put it on the 6bolt motor sence it came out of a AWD?
also the clutch i belive is about 3 months old as well but i will make sure
A related question so I'll throw it in.
What are signs of a good used clutch? Really haven't looked at em lately but I feel mine slipping. So what things should I look at?
This is not in reference to your clutch but wile your in there you should look for hot spots in your fly wheel. You'll not want to run a slipping clutch more thens necessary.
Be aware of any discoloration thats visible from both side of the flywheel friction surface. They are signs of bad clutch abuse. Hot spots that made there way through the entire disk are bad.
NT clutches are not interchangeable. The nt flywheels aren't stepped as the turbo's are, so their clutches are designed specifically to work with that flywheel and are 100% non-interchangeable. Take it from someone who's tried just about every combination.
All turbo clutches are interchangeable though.
I'm surprised nobody said anything about this. The answer is no, you can't take a 7 bolt flywheel and put it on a 6 bolt engine. As someone else said before:
6 bolt awd
6 bolt fwd
7 bolt fwd
7 bolt awd
Those are your flywheel choices for turbo applications. Since you have a GS-T and you're going to swap in a 6 bolt, you need a 6 bolt fwd flywheel. I recommend ACT or Fidanza if you don't have a lightweight flywheel already.
Thanks Kyle I didn't know that. I assumed that all 4g63 turbo or nt clutches were swappable.
6 bolt awd
6 bolt fwd
7 bolt fwd
7 bolt awd
This is 100% correct.
How can you tell the difference between a 6 bolt fwd and 6 bolt awd clutch?
Just wondering becuase i need a fwd for my 6 bolt swap.
I am going to assume you meant flywheel instead of clutch, because as stated above the turbo dsms all use the same clutch 90-90 fwd and awd. Stated above also there are 4 different flywheels, you can tell the difference between a fwd flywheel and an awd flywheel by the ring gears are 2 different diameters, the fwd is bigger around than the awd.(the part the starter hits). This is only considering the turbo modles, the fwd turbo and NT 1G flywheels are different also.
dad blast it now im going to have to buy a 1g 6bolt fwd flywheel :mad:
its already costing me $2100 for the motor + big28 tubro and the 350 whp clutch
btw do u guys thank thats a good deal ?
the motor probly has no more the 2-3k miles on it and the tubro i priced them around $500 and the clutch not sure how much they cost
