Wierd timing belt question
tsitalon03
259
Jul 15, 2007
SouthRiver, New Jersey
Ok so last weekend i got my timing belt/water pump changed....all that good stuff. Next day i got it back i noticed it idled like crap..but the car pulled alittle harder. So a few days later i got the timing adjusted and i lost that little "umph"...so what happened?
what happened is they didn't account for the exhaust gear movement when setting the timing the first time.
The cas might have been advanced some and that is why you had more power. Call and ask the shop if it was base timing they adjusted.
ok i called the shop today and they said they adjusted both cam and base timing....they said the cam timing was off a few teeth...so now what
how do i retard the exhaust cam only?
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
