Wierd Timing Belt Issue
headrec*
356
Dec 9, 2002
Ogden, Utah
the dowl pins are up every time the cams line up but the crank will end up in the same spot every time the cams line up (in other words the crank is not lining up). and other thing is the cars does run but runs like sh!t and loud ticking possibly piston tap. it will do 1 full revolution and everyt hing lines up the same
My friend actually used my name to post this but I will try to explain better. Every time the cams line up (dowel pins up also) the crank "noch" is in the same position as the rotation before it. Its would be very similar if the cams and the crank pulley had the same number of teeth. EXTREMELY wierd. I've never heard or seen anything like this. He can't rotate the crank by hand after a certain point but if you turn it over slow and line the cams up it is always in the same spot. Any suggestions?
I know. That's exactly what I thought and I didn't believe him. I was like you're doing something wrong I know it. But I got there and that's how it was.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
