Wierd Idle ?!?!?
Keithson30
121
Mar 11, 2011
OGDEN, Kansas
When I start the car it used to idle at 2500 rpm. I did a few tests, replaced plug wires, plugs, tested coil pack (as per haynes manual)
I did a boost leak test and no leaks found, went through the :
1G BISS Adjustment
I turned it down to 1000 rpm or so, but once i get to or above operating temp it will idle at about 4500 rpm. I cant stop it what else could cause this ?
