Tuning? wierd stuff!!
jhfgsx9d
35
Oct 1, 2003
Ok guys here is my problem !! i cant get rid of my knock no matter what i do !? i am currently running an FP Green on my car and no matter what i do knock will not go away !! even when i had my 16G on the car i could never get it to dissappear !! i have a brand new knock sensor in the car when i installed the Green !! so now im down to doing what i did wiht my 16G im going to eliminate the knock sensor !! im sick of dealing with it !! so my question to everyone is this what is the proper way to eliminate the knock sensor i want a clean look i dont want to have the sensor just dangling there with a ground wire can anyone help ? i know everyone hates the idea of doing this but im at my wits end here the car runs great the motor does not knock or anything and when i had this disconnected on my 16g setup the car was a BEAST so im looking for a clean removal please help please please please !! this is my choice so anyone who is going to say dont do it and yada yada dont post im looking for straight answers not peoples opinions!!
Thanks,
John
First off there's no need to use exclamation after every sentence!! Its kinda annoying!! Little things like this make people not want to answer!!
That being said, it says an FMIC is in your wishlist...are you running a green with a sidemount? (stupid question, but needs to be asked..)
Sorry about the exclamation points. didnt realize i put that many in there. yeah i already have a 2-216 core FMIC on the car and functional there is no way i woulda put a green on with the SMIC.
ok still going through this slowly...is lifter tick giving you phantom knock? How bad is your tick? Have you tried RESTORE ?
(sorry, second and probably last stupid question)
Do not use Engine Restore, unless you want to clog your lifters....
Rogue
Lifters are brand new. im not new to this whole thng i had my knock issues cleared for the longest time then they come back friday night i was driving around and found out what the real problem is ! i have a rod knocking right around 3k rpm im rebuilding the motor now took it out on saturday
I respectfully disagree. I, and many other people, have not had a problem with it. (I no longer need to use it, but the old lifters looked great when they came out).
Before I got an AFPR I was having issues with knock since the stock fpr was being overrun. Have you tried running racegas yet to see if you still get knock? That would help eliminate alot of possibilities.
Glad that you haven't had problems with it.... I however get chills just thinking about putting anything in my oil (besides oil). Especially when its metal (graphite, I think).... Kinda reminds me of putting sawdust in automatic trannies, definitely a temporary and destructive solution.
Rogue
Same here, now I just got boost creep. Seriously, a big pump without a good aftermarket regulator will give you more grief than a small one with the stock regulator. I was getting knock count to 20 at as little as 5 lbs of boost at part throttlle! AFPR took care of that problem. I know you found a rod knock but this is definitely a possibility.
John
John
i was going to install one of these while i was doing my rebuild i have a few modifications im looking to do while i have this all apart and that was one of them !! thanks for everyones input. i appreciate it
John
thats kinda funny to me, because i just had my dead knock sensor replaced, and im running a 255 hp w/stock afpr(untill i can get money to buy an afpr) and i have yet to see a single count of knock since i got the sensor installed(but at least the sensor works and it doesnt throw a code and the CEL anymore). i was kinda wondering why i wasnt seeing any knock with my set up
