wierd boost durring warm up
sexehtopper
1,117
3
Mar 16, 2004
lakeland, Florida
ok well i was driving with my dad out of the neighborhood and durring second gear i was boosting about 10 psi and i fell these weird power losses and boost drops and raises really fast, only does it the first coople of min driving from cold start. it did it again today leaving school, it did it some in first (but iw asnt boosting high) and when i hit second around 10-11 psi im looking at bnoost gauge fluxuate, and getting wierd power loss. help plz
I hope you're letting your car warm up before boosting or you'll blow your motor in due time...
there is a waring printed on your visor.
Let it warm up completely and then see what happens. The fuel maps change quite a bit once it's warmed up.
Your temp gauge will should be at the halfway mark, thats optimum running temperature. Usually it'll get warmed up after 5-7 minutes of normal driving. Once its warmed up punch it and watch the boost gauge and see how it runs. When was the last time you did a tune-up (ie. plugs, wires, fuel filter, o2 sensor, oil change, etc.)?
You should replace all those wearable parts every 40-50k miles except for the oil of course! Do that every 3-5k mile depending on how you drive.
