Wide bands to be used with MS
glowryder
855
10
Jan 23, 2004
des moines, Iowa
Im running MS full stand alone. Im using the AEM uego, i hate it , its off .4 afr. the guage reads differntly then the voltage its outputting to MS.. so what are you guys using, and hows it working for you? im wanitng to go innovate, but i dont know which model to run, idk if LC1 would work with MS, etc..
so then you can verify the gauge matches the voltage / reading as your MS? i thake it by using the same calibration on bothe ms side and LC 1 side?
and did you instal the + 12V for the sensor/gauge to the same 12v the MS is on?
grounds i imagine all go to the same place as well.
Where the +12V comes from doesn't as matter as much as where the grounds are.
Also, FYI the LC-1 doesn't include a gauge by default. The MTX-L, which is similar to the LC-1 (and the same price), includes a gauge.
