Using Stock Sensors with MS-II
tec_41
342
7
Nov 23, 2008
West Bend, Wisconsin
I was reading that I'd be able to use the stock IAT and coolant sensors with MS-II, but what's the proper way to do this? If I just cut the wire and run it to the MS ECU I would imagine that'd mess with the fan controls and everything. Do I splice into the wire and leave it hooked up to both ECU's?
Same thing goes for the IAT sensor...Thanks for any help!
No. You use your stock sensors if you are running standalone, two ECUs cannot share the same sensor.
Thanks for the reply. My initial plan was to leave the stock ECU in place and do the minimum wiring, like Bullett's guide...but he uses the extra aftermarket sensors- 2GNT.com -
So are you saying I can just take the signal wires off of these 2 sensors, and send them straight to the Megasquirt ECU? If this is right, how does the radiator fan know when to kick in?
As long as you're running your MS as a standalone controller, then yes. You'll also have to ground the other wires where the MS is grounded.
If you've removed the stock PCM, there's nothing to turn the fans on at all. You typically connect a programmable/general purpose output from your MS to the fan control relay and tell it when to activate the fans.
If I'm going to keep the stock PCM, then I would need to add the GM sensors for Megasquirt to read from, correct?
Perfect, thank you.
I ran into a little issue with the wiring harness from Symtech Labs...here is a photo of my harness compared to the wiring guide from Symtech Labs
Note how in the Symtech guide it shows the blue injector wire closer to the outside next to the brown and purple wires. But my actual harness has the GREEN injector wire closer to the outside.
Look like a mistake in the harness?
Perfect, thank you.
There may have been a change in the harness that isn't reflected in the diagram you posted. Either way, it doesn't really matter. You'll be using batch injection so using channel two as channel one makes no difference.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
