Why won't it run?
Bushido1346
Jan 4, 2014
Harriman, Tennessee
My car won't stay running after I changed the turbo it starts and ran for a minute then died but that was with the intercooler hose goin to the throttle body but nothing with it back on and then it flooded so bad the smoke came from every that smelt of gas
There must have been an installation error, maybe if you have some pictures we could find something easy you forgot to do, other then that Boost leak test is also a good idea, like insane20 said.
Boost leak? Would that cause it not to run. I didn't even think of that.
The o2 sensor isn't connected to the pms or the ecu. But I don't see why that would keep it from running with the intercooler pipe is on the throttle body or off.
I do have a piggyback system on the ecu
Ok now I have the AEM o2 it's hooked to the gauge but doesn't run to the ecu yet I feel that may be beyond my electrician skills
I have a tial wastegate and it vents from nothing I have an AEM o2 sensor and I'm sure it's leaking boost all my hoses were good it's got a gm map and a mad both of wich I think is hooked up how come it runs better with the throttle body hose off
Maf sensor not mad spell correct
Everything looks fine I don't have a wastegate vacuum and how do I connect the o2 to the ecu
