Resolved why do you need to do a resister back delete
TalonFULLtune
107
7
Jan 15, 2013
three churches, West Virginia
i see people talking about doing a resister pack delete i know how to do it. you cut the pig tail and connect all five wires together. but why and what is this for exactly???
just started to build my first dsm.
...turbo cars have an injector resistor pack on the firewall to provide current limiting since the ECUs use the same injector drivers for Turbo and Non-Turbo. Putting low impedance injectors in a N/T car will burn out the drivers without the resistor.
Steve
So, if in your turbo car you want to use high impedance injectors, the resistor pack needs to be "deleted".
so what if you use high impedence injectors in a turbo car. u dont need the resistor?
Benefit ? I guess resistors wear out over time, so without the resistor pack, there's less to worry about/replace in the future ?
in my case i gotta do a delete plug cause im running 390cc grey top auto turbo injectors on a nt ecu ( car came with turbo ecu and fpr soleinoid , resister pack ,bcs ect. no turbo tho so i picked up nt injectors (240cc) pink tops, and am looking for the facotry plug so i can delete it but can turbo when i can afford to getter done and the difference is high empendance and low is the cycle the injectors take low empendance opens faster than high
makes perfect sense just never thought about it. kinda of stupid to run the resister when our ecu are made to run high. yea i seen the kit i want to do a semi tuck bay so i think im going to the high and just cut the pig tail and twist the five wires together. that gets rid of one more thing out of the bay.
