97-gst
- 1,234
- 1
- May 16, 2010
Radford,
Virginia
I just wanted to know why 1g's had less power? I thought the 14b was alot better than the t25 and you could get 100 more hp out of 14b?
"If you get back on here with issues., I will Chuck Norris drop kick your a$$
" Nah, I won't tell even though, after an Knock Sensor (old one had a torn wire) ECU and CAS replacement (only three problems I've had and these were done a year after after I got the car..) I've gone 21k miles since I got the car over 2yrs ago, and with road trips with cruise on at 80mph still getting close to 30mpg....and can still blip past buzzy little Hondas who wants to take me on ...Oh, I do have a B16G in it since the motor came out of a VR4 instead of the 14B.Prob why users love putting 3 inch exhaust piping in place of the stock piping ...and 190 for the FWD as the exhaust is a bit more restrictive
its also way easier to work under the hood of a 1g.
Boost setting difference was the first thing that came to mind. I'm kind of surprised nobody mentioned it sooner. Maybe because everyone usually disconnects the boost control solenoid & forgets what the factory boost was
! So what does disconnecting this solenoid do? Yes i see it controls boost but what happens when its unplugged?You do that there buddy. . . If you get back on here with issues., I will Chuck Norris drop kick your a$$. . . Really, run premium.
just another .02 is that the bowl of the combustion chamber is different from 6bolts to 7bolts and Maby that is where the hole premium fuel/ regular fuel comes into play..
Did they change the timing map from 1ga's to 1gb's? or only when they made the switch to 2g's?
also the 2g has a different o2 housing..
The 7bolt has lighter rods more responsive, and a main brace too. like was said before slightly highter compression too. with all that with a good tune the motor will hold 400hp
The t25 come on guys with all mods and 17psi was fun
hits full boost at 2500rpmOh, the misinformation in this thread is awesome.
The t25 come on guys with all mods and 17psi was fun hits full boost at 2500rpm
The compression is higher(smaller CC combustion chamber), Boost pressure higher(turbo is smaller and would produce a higher air temp).
