Who rebuilds ECU's?
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
Ok im guessing that my ECU is bad due to my car not starting and no CEL and i took out my ECU and 2 spots the looked like 1 drop of oil spilled on it (right next to the 2 bigish looking batterys) so..who can rebuild this thing the dealer wants 1200 for a new one
Those resistor caps get leaky, it is a common thing to happen. If you search on here, there are several vendors you can send your ECU to and have it rebuilt. I don't know the cost, but definitely less than $1200. If all else fails, you can get a used EPROM ECU on Ebay or in the classifieds here for around $150-$200.
+1 on steve and ECMlink, both them know their stuff very well on the electronics end. You can also take your ecu to Advance Auto Parts, and get a rebuilt one for $300, this is the route I went only because I was not yet a member here, so I didn't know there were other options. I wish I would have just sent it to steve instead, from what I've heard about his work, it's better quality and the turn around is at least equal to Advance.
i would go with steve or ecm link. always here good things about both! good luck with that. hope that is the only problem you are having with the car!
Exactly! Steve will pop up here soon.
I took the night off. :) Thank you all for the kind words.
Alex, those battery looking things are the capacitors. The fluid inside them is the electrolyte and it's corrosive. If you don't get a CEL for 5 seconds when you turn the ignition on and you have checked the MPI and Ignition fuses on the positive battery terminal then it's very likely the capacitors have leaked and eaten something important.
How do i test the MPI relay i found the terminal gettin 12V and i dont know witch one to ground
at what point is the ecu garbage after the caps have leaked?
At the point where the cost of the repairs exceed the cost or replacing it. The replacement cost varies from market to market. EPROM ECUs are rare, 90's more so, so the replacement cost is usually always more than repairing it.
Two cases that I can think of make an ECU really dead, bubbled chip packages on the CPU, or port expander (EPROM only), burning though the circuit board in more than a tiny spot.
Extensive corrosion spread across the board is usually not worth repairing for a non-EPROM.
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
  • Wanted 2g Tan Door sill trim
    Looking for passenger and driver side door sill trim in tan color. Let me know what you guys...
    • Mahreeoh17
