1G Which way does the coolant flow in the FIAV
1992 Eagle Talon TSi
78
Oct 2, 2012
St. Louis, Missouri
Got a question about the coolant flow through the throttle body. Which way does the coolant flow for the fiav? Does it enter the left or through the right?
I have been searching for awhile and can't find an answer. There really isn't much of a reason for knowing so please don't post asking why I want to know.
Thanks in advance!
90 year model throttle bodies have both ports on the right. Haven't looked at a 91+ to see if they are different...guess they are??
On 91+, the return is the port on the driver side of the throttle body. The feed is on the passenger side.
On a 90, the return is the top port and the feed is the lower port.
In both cases, the feed is from the thermostat housing. The return is to the water pipe.
