Which way does the cam angle go in?
shadoof77
166
Feb 18, 2010
Here In, New Jersey
So yea, I just put the head back on from tearing it all apar to fix a headgasket. Well now i'm stumped on which way the cam angle sensor goes in. Does it matter which way it faces when putting it in? What would happen if i put it in the wrong way? thanks
On the cas there is a notch and a line that must be lined up. with all your timing marks aligned the cas will go in straight and not need to be moved. if you do it properly the ignition timing should be right at 5* btdc
what you are explaining is the engine turning over i believe what you are trying to say is that it wont fire. you may want to verify that you hooked all your connectors up right make sure the wires are in th correct order. and also verify that the timing marks all line up on the cam gears with dowel pins at 12 o clock and #1 cylinder at tdc. perform a compression test also if you have the ability too.
yea i dont think it wants to fire. The spark plug wires I looked in the haynes manual and called my friend up and asked him how his was setup and the book and his were the same... and I just went to try to start it again it wasnt even turning. Then the third time i tried it started turning but only for a second then stopped.
