which pistons?
nogospyder
May 3, 2004
Eugene, Oregon
I just bought a 6-bolt block 4g64 and was wondering if the big rods and 95-99 pistons would work or if i would be better off buying the weisco pistons to run the 4g63 head. :confused:
Do some searching there is tons of info on here about stroker combos.
I belive you need a special piston when running the 4G64 crank. You can use the 6-bolt rods but you will need custom pistons with the wrist pin located up higher.
