where will i hit fuel cut?
Oki have a big 16g turbo, mbc, fmic, 255 fuel pump and full exhaust (manifold,o2 housing,DP, and catback)in my car and im running about 16-17 psi and i cant even go over half throttle without hitting fuel cut, safc on its way.Do u think that will fix my fuel cut? A little off topic how much vaccum should i be pulling at idle on the boost gauge
You might need the SAFC and some injectors to run that much boost.
You should be between 18-20inHg, like mentioned earlier in the thread, definetely do a boost leak test.
I would stay no higher than 15 max on stock fuel and once you buy exhaust and down pipe you will have boost creep like a mofo. I have a apex exhaust and I have to use the silencer to keep boost creep in check
well im getting the fuel controller safc but i was hoping to tune it to run with the stock injectors if possible, cant afford the injectors right now, but on the boost leak issue i ran a boost leak test and my bov was leaking got a new one and i dont hear any leaks other than just a little one from the oil cap but i dont get any movement from my boost gauge.
i found a leak by my throttle body elbow (upper ic pipe) it sounds better but i will try another boost leak test now and see but i should see movement at my gauge right, and is it normal to have a leak at the oil cap? thanks again
yeah i am gunna go with dsm link over safc and then get injectors 255 and what not so its gunna be for me
1. mbc
2. apex n1 dp and wchaust
3. dsm link
4. mods like injectors and what not
I’m havin the same problem with my 1997 Eclipse gst everything stock other than evo 3 big 16g, 510cc injectors with Greddy profect b boost controller with walbro 255 and hitting fuel cut right away I also have no tuning software in this car. I run Efm link v3 on my other one but this one nothing yet
