1G Where to find bushings (1990 1G fwd)
Purple_T63
37
22
Sep 4, 2022
gatineau, QC, Canada
I am looking for a lot of bushing for my car (1990 1g Talon fwd) and either cant find any or the brands dont have any reviews so maybe I am out of luck ... I plan on using the car on the track (no drag) and on the street but I dont mind loosing a bit of "street" ability if it makes a difference on track. I know that I will have to try out a lot of this stuff to see if it fits my needs but I want a good base non the less. Anyways, I am looking for : SUBFRAME and if available all other SUSPENTION bushings, SHIFTER BUSHINGS oem works but if there is an aftermarket stiffer solution I would prefer. I plan on running an aftermarker sway bar in the rear also if they exist for fwd's.
I forgot to add that I have seen some bushing on the 3d dsm creations website but I want to see all the options I have if there are any.
You mean suspension and subframe? Try perusing the Supporting Vendors sites. I've seen those plenty of times, though I don't focus much on the fwd availability, but I believe urethane versions are plentiful. A little stiffer to suite more aggressive driving at the expense of some comfort.
In addition to link by @pat white , the other option I am aware of is Prothane.
I'm pretty certain you'll be hard pressed to find a sway bar for the rear as the 1G FWD only has a pan-hard bar or lateral rod, not an actual sway bar - see unnumbered item above #14 in the below illustration, or # 25 in the second illustration.
What I'm saying is that a panhard bar is not a sway bar. The "sway bar" in a 1G FWD is more part of the solid axle, #14 in the first diagram above, listed as the torsion axle and arm assembly. A panhard bar is mainly for purposes of locating the rear axle, ensuring that it maintains position laterally (side to side). A sway bar is used to control body roll or lean by transferring the torsional forces in the bar back to the vehicle suspension to maintain a more level ride.
You can replace the panhard bar with something else but it is still going to be a panhard bar of sorts and not a sway bar. Unless there is something wrong with yours, I do not see a reason to and really would not recommend it. The panhard bar hardly weighs anything as it is so there would not be much benefit to it.
