1G Where to buy MPI fuse
sqr
82
Apr 3, 2009
Lancaster, Pennsylvania
93 Eclipse na MPI fuse
Can i get one at a parts store and how much? It flew from my fingers when i pulled it to do a compression check. It is some where behind the engine or under the battery box on mt 2.0 na. Is it worth while pulling the battery to look for it ?
It went down hill from there. Compression is 146 to 154 and there is more oil on the t belt than when i checked 8k miles ago. Do valve cover gasket leak in this area or is it more likely a cam or crank seal.
Car has 186k. Oil consumption / leakage is 1 quart per 700 mile.
I'd pull the battery, and find it. Also yes the valve cover can leak there, and yes it could be the cam seals best way to tell is replace one or wipe it off, and see if you can see where its leaking from. This reminds me I need to replace my valve cover gasket too sometime.
Thanks for the replies. I found it pretty quick after i pulled the battery. I really should replace the valve cover gasket as it is definitely leaking at the trans end as well.
sh...it i have an extra one laying about (MPI relay) i got it when i got a wiring harness off some dude.. not really sure if it works dont' know why it wouldn't it looks good, haven't tested it, dont know how really!
