Resolved 1G Where is the MPI fuse
Executionerhk
130
Feb 21, 2008
Topeka, Kansas
http://www.geocities.com/dsmgrrrl/FAQs/compression.htm
This link is about how to do a compression test, I think everyone knows it, but my problem is my positive terminal of the battery only had 3 fuses and they are the same color. I cannot find the blue one that the dude was pointing at in the link.
btw, I have a 90 Plymouth Laser 5spd RS turbo.
if need picture i can do it.
Can anyone help?
Also share how to do the compression test right the first time.
I am about to do my first compression test and I want to know more detail before i go do it.
Solution
I have the same car as you. The fuse must have been changed. Just pull the fuse from the position shown & follow the directions. Its a basic test, you shouldn't have any problems.
Solution
so should I pull the third one or the middle one...
because i only have 3 fuses..
