2G Where is the MPI fuse?
SpoolN
386
Jan 20, 2003
Coventry, Rhode Island
Im trying to do a compression test and I cant find the MPI fuse any pics or anyting would be appreciated.
Look at your battery, theyre 3 fuses right on top the positive side, one says MPI, pull that fuse, and disconnect the coil pack so you got a no fire no fuel condition, then proceed with compression test
It is listed as the MPI, ECI or engine fuse and should be in you underhood fuse box. It is a twenty amp fuse. Also, unplugging your coil pack is not a bad idea. Letting them spark with no plugs can damage them. You could also unplug the cam or crank sensor but that will set a code as you know.
bringing a thread back from the dead, but i have a 97 eclipse and cannot for the life of me find the stupid MPI.
1g and 2g are different. 2G's MPI is NOT near your battery. So anyone know where it is????
