Where to buy holset turbo
chrisb33
137
Feb 20, 2008
Manila, Asia
I've been reading a portion of the Holset turbo threads at the turbo tech section but i honestly cant keep up reading all of them coz it's just too long. But i think ive read enough to consider this brand.
Problem is, i cant seem to find a vendor selling this turbo. Can anyone point me to a site selling these turbos?
Also, my goal is to reach 400whp with a fully rebuilt 7 bolt with all the supporting mods OR a 6 bolt block also with all the supporting mods (still debating on which route to take).
Thanks in advance.
chris b
galant's ran 7bolts?
Anyways you can get them from an dodge cummins fourm..came in 94-02 dodge's i believe
Im going to try to get mine from wyotech since im moving up there for school january
ebay, cummins forum, or the junkyard.
Although the ebay ones are somewhat expensive...you can find them sometimes on there for dirt. I'm searching for one now as well...and eBay is doing me NO good LOL.
But just keep looking everywhere, and yes, a holset will get the job done for you. You won't need to build the block for your goal - the only reason I lightly built mine was because it was a good deal and I got it already put together. With ported 2g mani, cams, the boost up, and a good tune, you'll find you're making 400 hp.
I think most people would recommend using a 6 bolt as the starting platform. Like mentioned above, eBay is a great place to get one or on a cummins diesel forum. The turbo you would be best with would be an hx40. The next best choice would be an hx35. The trucks your looking for are the 94 to 01 Dodge 1500, 2500, or 3500 series with the Cummins obviously. They are known as the 2nd generation trucks. Don't worry about what exahust side is on the truck. (The Turbo Trader) < --- sell bolt on Mitsu housings for the hx35 and hx40's...
Before you buy Holset, you must decide what kind of manifold you are going to run: Mitsu/stock/, T3 or T4. After that you look for what ever turbo suits your needs- hx-35; hx-40; H1C; H1E. This will save you money in the first place.
It was an engine swap. But yeah there were 1g 7 bolts on galants.
eBay is you want to go the cheap way but you'll have to rebuild it or Tims Turbos or Turbo Trader if you want to go knew with a BEP bolt-on housing.
If you're only shooting for 400whp you don't need to build the block. Mods to the head can do it like cams, valved, etc...
well my engine is due for a rebuilt already. it's completely bone stock and i actually spun bearing number 3 already. since it's my daily driver, and i didnt had that much cash on my me when it happened, i just had my crank regrinded and used cheap bearings on it. Everyday i drive my car and boost 15 psi only, i get scared that i wont be able to go home hahaha.
but now i've saved up and im getting ready to do a reabuild. Not enough for forged internals though. I got already new 2g OEM pistons and rings, i have a used 7 bolt crank that i got for free, planning to buy clevite rod and main bearings, ARP studs all the way, cams, springs and retainers, etc. As mentioned above, i have a 6 bolt N/A block just sitting in the garage, so i have 2 options on the build which im still debating on.
chris b
if you have a 6bolt, id do that one, and you dont have to go too crazy with the build. the block i have i love, and it didnt cost me out the ass either.
just make it bulletproof, you dont have to make it SUPERBLOCK u know?
I would prefer a mitsu manifold because i dont want to spend the extra$$$ on having a customized tubular manifold which i can have my local exhaust shop do here. Having said that though, if the holset turbo i get does save me a lot of money, then i can get whatever holset that is available and have a manifold built for it.
as for the turbo, im looking for something that flows more like an FP 18 or fp 20g (or bigger) im not familiar with the holset models so your help will make my holset shopping easier.
I got mine from ebay for 295 shipped with 40k miles.
Do you have to rebuild these turbos even if they have xx,xxx miles on them? or are they as strong and reliable as the holset threads say they are?
if in case the internals get damaged, where do i have it fixed? those are the things that worry me.
chris b
yup i my thoughts exactly :) thats why im not going to spend on forged rods (much more on the freaking expensive forged crank), so "super" bearings and fasteners would be enough for me :) they're affordable anyway. Plus i got a super cheap deal on 2g OEM pistons and rings so i can use that on either block. but before i buy the bearings, flywheel, clutch, ARP's...i'd like to make a decision first on what block to use. If only i could transfer my oil and water pump on to the 6 bolt from my 7 bolt, id be right on it, but thats extra $$$$ which i can spend on other parts on my wish list though.
So in the meantime, what im shopping for are parts that can be used on either blocks like the turbo :D
2g pistons GREAT CHOICE LOL
no i feel you there. i got my block @ a steal, already assembled. passed compression test so im happy.
hahaha yeah. only did that because 1) i was originally planning on rebuilding the 7 bolt block, 2) it has a higher compression than OEM 6 bolts, and 3) im running meth anyway so helps me safeguard the pistons :)
chris b
i like the high compression, that way wen/if i go to water/meth im safe, but even without, although it needs more fuel i dont mind it.
i havent been able to take the car over 4000, bc my speedo is broke, so my stutterbox is stuck on, but once i get that fixed, LOOKOUT. I can tell you that 4th gear, a stomp its alot stronger than my stock 7bolt with 14b.
ps chris - u have pm!
PM replied. Go and get the meth kit. One of the best investments ive done so far for my car. Before the meth i was reading at around 4-7 counts of knock at WOT, thats with the DSMLink already and fine tuned. But since the meth, without even tuning it right now, close to ZERO knock. And intake temps went way down when the meth is injecting.
chris b
im looking at the hx40, what variant should i aim to look for? also, what injector size should i go for with this huge turbo?
i already have upgrade fuel lines, rewired wally 255, AFPR, meth7 meth kit. right now ive got a measly 510cc but planning to upgrade to FIC 780's.
tia.
chris b
If your running dsmlink get 1000cc or bigger so you have room to upgrade, but 780cc would be fine. Some guy made 657hp or something like that on the hx40 in the bolt on housing. I have an hx35 with the bep t3.70ar housing.
Got ## pm. thx for all the info.
i dont remember, are you going to do BEP housing or T3 or T4 when you go to this holset?
I suggest you go even bigger, well you have dsmlink so u can go to WHAT THE HECK ever. I want 880s, Id suggest something in that range, ### there have been guys that maxed out 780s or so on 16gs. I'd say go big, and if you ever blow a turbo up, or downgrade, u can turn the injectors down, and thats no problem. its better to have more in there and not use it, to not have enough, and have to back off the throttle or not make enough power or run 100+% bc ## injectors are too small. If I wasnt so damn hardheaded I woulda got the 880's or 980's the FIRST time and been done with it.
I think im going to get the 880cc it's the biggest injector i can find on the budget im willing to spend on for injectors.
Im still confused as to these holset variants are and which ones to get. I've been trying to read the holset threads everyday to get more info, but im still in "part 2!!!!"
As far as i know...for my goals, it would be an hx40 or at least an hx35. And theturbotrader has both i think brand new but for the price...id go for an FP20g. However, if i do get one on ebay or cummings forum cheap, i know the rebuild parts are super cheap for holsets, and i can get a BEP housing from theturbotrader...i think it will be a cheaper, solid, more powerful turbo than the 20g.
oh these holet turbo's can be clocked right?
chris b
