Where to buy door Weather Stripping?
95TalonTsiAWDam
86
Jan 5, 2005
Grenada, Mississippi
Searched but could find any info...anyone know where I can find 2G door weatherstripping? uppers and lowers..and the window to glass "drag" seals too.
Thanks,
MM
Yes...I mean weather seals or where the door glass touches the rubber seal. Didn't see it on JnZ. I'll check mitsu website...
Thanks guys,
MM
Thanks guys,
MM
Alot of things still aren't listed on their site. Just give them a call. Erik is very helpful with whatever you need.
Sorry dude but I don't think the dealer sells that seal. My 95 tsi has very hard seals and the upper seal of the door frame is available but the lower part that actually touches the glass is not in CAPS. I called a couple dealers and they didn't even know the part came on the car until I brought it in. I had to go to a junkyard and pick one up even though its only going to last for a year or two before it becomes hard and brittle.
Yes they do still sell it. I orderd mine from jnz 2 days ago upper and lower.
Ok dude I'm talking about the upper seal still. There are two parts to the upper door seal. There is the most visible part that most people replace because the rubber on the metal is starting to peel and the metal is showing. Then there is the actual window seal underneath the upper seal that the window tucks under when closed. That seal is seperate from the upper main seal and cannot be found in CAPS or the few dealers I went to.
Every part should be listed in CAPS, just need to know how to search properly. If I get a chance later I'll search for it, depending on the dealer their sometimes not the greatest at finding things. Though if the dealer doesn't offfer it, obviously your not going to find it anywhere else, unless some other aftermarket company makes weather strip seals for our cars.
Thanks daren_p... if you get a chance, I would appreciate that. And yes SoonToBeDSM06, that is the seal I am needing...hope daren_p can get us a part numbe for it.
90blacktsiawd, did you order this seal from JNZ or just the outer part?
Thanks,
MM
I did a quick search when I was looking for other part numbers last night & didn't see it. I checked the logical places but that isn't always where you end up finding it. I think I saw every other seal but the one you need. Did you get the numbers for the drag seals, if not which ones are you looking for, inner,outer, driver or passenger?
Sorry for resurrecting this thread, but I'm also looking for the same part (seal). Do you guys think that #7 is the correct part? It's listed as the "Glass Holder," which is somewhat confusing, as our doors don't have window frames.
