Where to buy??
TonyTSi
62
Oct 11, 2002
Minot, North Dakota
I was wondering if any of you DSMers out there could give me an idea where I could pick up one of the Concept Racing Crank alignment dowel kits? I can't seem to get ahold of Concept Racing themselves, and MachV is out of them right now. I have been searching performance shop websites and can't seem to find it, anyone got a clue?
Thanx in advance
Tony
My understanding from the concept racing website was that it was the same kit for all 4G63 motors, but if there is a difference its for the 6 bolt sir.
Tony :talon:
nevermind...
The bearing cap on Mitsubishi 4G63 motors is held on by studs or bolts that penetrate through holes in the bearing cap. Those holes are machined larger than the bolt/stud diameter, and that can allow the bearing cap to shift under pressure. This shifting is a POSSIBLE explanation for the premature thrust bearing failure (or "crank walk") seen on some late-model 4G63 motors.
The Main Bearing Cap Alignment Dowel kit from Concept Racing tightens up those holes with precision-machined steel inserts. The kit is designed to be used with ARP studs when you are re-assembling the engine. The inserts are inserted into the bearing cap, then the studs then fit through the inserts, into the block. The result is a nice tight fit, with the bearing cap aligned and centered correctly, with no chance of it shifting around under lateral loads.
We're not saying this is a cure for crank walk, but if it were OUR motor, we'd use these inserts. It's cheap insurance against a problem that can cost thousands of dollars.
Kit includes ten specially-machined cylindrical inserts, and complete instructions. Fits all 89-99 4G63 blocks.
Do a lot of people use these?
Thanks
If you still have them would you be interested in parting with them? Hit me up PM if you are. Thanks
Tony
