Where to buy 92 gear selector lever for Awd 5 speed
Blownuptsi92
60
Oct 5, 2011
Fenton, Missouri
Need a 92 talon Tsi gear shift selector lever. I can't find one at all. Im in need of one to put my trans in anyone know where to get one?
Which part are you looking for exactly. The part that bolts to the bellhousing with 2 bolts or the part that is on the shaft with a press pin?
Believe it connects to the shifter cables. I don't have it here next to me unfortunately
IF you look at this pic you will see that there are 2 arms that the shift cables hook to. Which one is it.
One of them bolts on, the other has a press pin that is nearly impossible to remove. I am wondering how someone actually got yours off. Take a pic of what you are working with.
Your right I do have that press pin part. I'm missing that arm/lever or part of the shifter assembly. Where can I order that? Can't find one anywhere?
