Where is the ignition control Module
The 2g N/T drives the coil directly from the ECU (actually called PCM).
In other words, no ignition control module.
ASD relay (auto shut down relay) is on the firewall. Your starter Relay located behind the radio.
I dont see it behind the radio on 99 420a rs are you sure your not talking about 4g63 turbo setup
try underneath the radio,
