Where does this plug go????
SlowButSpeeding
Apr 29, 2004
Atlanta, Georgia
Ok... I've done some searching and I now know that this plug is for the hood switch (related to the security system)... HOWEVER, I'm not exaclty sure where the plug actually goes. I've repaired the entire front driver's side of my car from an accident, and this is the only piece that I can't seem to find its home. Anyways, I borrowed some of these pictures from another thread so you'd be sure of which switch I am talking about. Thanks in advance for the help.
Drew
The hood switch should be bolted to the radiator support just behind the driver headlight and to the right of the hood prop rod. I have included a pick but its not the best. You can see the bracket where it bolts down but you have to look close. If I had any image editing software, I would circle it for you but since I dont, Im sure someone else will :thumb:
