Help! Where does this plug go?
Flory525
Jan 18, 2010
veradale, Washington
So i am rebuilding my 1991 gsx. I took apart my engine and i thought i had taken all the bolts and plugs out and so i took the block to the machine shop. When i got it back this plug was in a bag with the block. Now i cant figure out where it goes. Sorry that it is a dumb question i just need help asap. Thanks.
Nah look in the back of the block where the rear main seal goes,this plug screws in somewhere around there
he took the block to the machine shop not the head,this little plug will leak engine oil if not sealed properly,its not a freeze plug
It's an oil galley plug. They need to drill a hole straight through the block for the oil galley, then they need to plug the hole where the drill went through the outside of the block. So they thread the hole and screw that in there. There probably is one behind the flywheel, for the main-bearing oil-galley, but IDK; I've never tore down an (4g6)engine that far. I could swear I've seen them near the oil filter, and near the thermostat housing. Just look for a threaded hole that doesn't have a flat surface machined around it for a part or a bolt head.
did the op fall asleep on us LOL,he's getting live help here.Yeah i know its somewhere around where the rear main seals goes behind the flywheel
Could be. They are the same 3/8" Tapered. The oil filter housing plugs have a different part number too.
MD145018
If he had taken the block to the machine shop, I would assume the OFH was not attached.
my point exactly
01385q - plug, cylinder block taper, 3/8" <----
01385p - plug, cylinder block taper, 1/16"
01385s - plug, cylinder block screw, 10
Lol this was the first thing i ever posted and i was not expecting to get replies that quickly.
I found where the plug goes! Thanks for all of your help. The reason i could not find it was because the block was on an engine stand and that covered the hole. and just in case anyone else wanted to know where it went ill add a picture showing where it went. Oh and once again thank you every one who replied.
