Where does it go ?
Uber10
Mar 23, 2012
Montgomery, Alabama
dont know where these parts go if someone can take a pic and post them that be awesome :)
The first part is a lever for the transmission. I will take a pic later of how it goes on I have mine apart at the moment. The little black plastic piece goes below the A/C compressor it has POP rivets that connect to the side of the subframe. It is a useless part I just took it off and left it off.
Why would your shifter lever be off then? Guess you didn't take pictures eh?
because we were replacing all the parts for the clutch and yea i didnt take picture im hating guessing where everything goes.
That's not a part that comes off unless you tear the transmission apart (excluding the clutch).
With the fuse box holder, you basically just figure out which rotation of the bracket will allow it to line up with the holes provide so you can bolt it down.
I tossed the plastic piece.
