where can i get some .060 pistons
DanGST
352
Oct 8, 2010
Bronx, New York
I am looking for some pistons to put in my 4g64 and im having trouble finding them can some help me please
You may have to contact the piston maker and have a custom set made to the size you need.
Why are you going .060? Is that needed to clean up the block or are you trying to make more power doing this?
The 4g64 block is .060 over then the 4g63 block so I need 4g63 piston that are .060 over to fit correctly in my 4g64 block.
Where can I get them from. I know wiseco has and wants 500. But I know I can get some cheaper
So you're asking for .060 over pistons because you have a 4G64 block, right? I hope your not trying to bore a 4G64 block oversize by .060 because that would be too big for the headgasket to seal right.
This page lists almost every piston made by Wiseco;
Import Performance Parts - Mitsubishi Wiseco Piston
He is asking for .060 4g63 pistons. The 4g64 is .060 bigger than the 4g63 bore and the 4g64 block has an extra 6mm of deck height to make up for the height of the piston so a .060 4g63 piston will it in a 4g64 block. I would call around to some machine shops and see if they can get you a cast replacement .060 piston for the turbo engine. You should be able to find a set for 200 or less.
Will they hold 500+hp?
You do not want to put a 4G63 piston in a 4G64 block due to the wrist pin location difference (due to different deck height). You need to make sure you get a 4G64 piston.
