when getting to run a log... you need???
myeclipseisnice
381
Sep 2, 2003
south river, New Jersey
when getting to run and rec a log you need to see... rpm, o2, timing and what else? what if knock isnt available to be recorded.. is knock mandatory to have and record?
kelvinb said:
what are you using to log? mmcd? dsmlogger?
not sure yet but what does that have to do with my question? i will have a safcII to tune and not sure yet on what to use to log it... but was just curious about the knock and everything
I'd take the best of both of the above. Check TPS once to make sure you are getting 100%, and then log RPM, Knock, and Timing. Timing is important to see, you may be seeing no knock, but only getting 8* of timing. This would be nice to see.
